I have 2 files: dgn1 (main data) dgn2 (reference) The two files should be checked against each other for duplicates. In the end, the dgn2 should be recreated without the duplicates contained in dgn1. Please help. Thanks.
  • Jul 12, 2022 10:18 AM UTC
  • 7 replies
  • 83 views
aharport
Forum|alt.badge.img+4
geomancer
Forum|alt.badge.img+71
  • Jul 12, 2022 11:57 AM UTC
Try the Matcher and/or the ChangeDetector.
aharport
  • Jul 13, 2022 3:16 PM UTC
Thanks, unfortunately the transformers don't work.
dgn1 contains cells and dgn2 contains texts that have the same insertion points.
Apparently the problem is that no texts are matched with geometries in the transformer.
How can I convert the texts to points or cells before the matcher transformer so that I have a geometry to geometry comparison? However, all other attributes should be retained.
geomancer
  • Jul 13, 2022 3:25 PM UTC
Alas, I don't have enough knowledge of DGN files in FME to help you out here.
I hope somebody else can look into this (new) question.
keziaatsafe
Forum|alt.badge.img+8
Hi @aharport​ ,
Would the duplicateFilter transformer help in your case?
-Kezia
aharport
  • Aug 15, 2022 9:36 AM UTC
Hi Kezia,
unfortunately, no
geomancer
  • Aug 15, 2022 12:33 PM UTC
The bright minds on this forum may be able to help you better if you can provide them with some sample data, like a small part of dgn1 and the corresponding part of dgn2.
jovitaatsafe
Forum|alt.badge.img+11
Can you try disabling 'Expand Named Cells' in the reader for DGN 1? That will allow you to compare the insert points.
