HTTPCaller version 2022.2
  • Dec 1, 2022 9:05 AM UTC
  • 21 replies
  • 281 views
dxirgu
Forum|alt.badge.img+4
Hi!!
I've got a problem in FME Desktop 2022.2 that I did not have in FME Desktop 2021.2
I have a workflow that makes POST request to ArcGIS Print Service in order to get an image of a map. We upgraded version and this workflow it doesn't work right now. It shows the following error:
"The encoded string is not a valid fme-wwjd string"
The content of this string is a JSON that I need to do my request.
As I sayd, the same workflow it works on version 2021.2
Does anyone has any idea what happen?
Best answer by david_r
After further testing it seems it's the extended (accented) characters in the JSON document that is causing this error. I have a suspicion that it might be a bug in the HTTPCaller, because if you use something like the StringDiacriticRemover to "simplify" the JSON before sending it to the HTTPCaller, it works. I recommend you reach out to your FME reseller or to Safe support to confirm.
  • Dec 1, 2022 9:10 AM UTC
I think you'll have to show us example data, or perhaps even better, post a sample workspace that demonstrates the issue.
Secondly, "wwjd", someone at development clearly had an epiphany that day ;-)
dxirgu
  • Dec 1, 2022 9:56 AM UTC
Hi @david_r​ ,
this is the configuration of HTTPCaller
httpcallerAnd I attach JSON file
dxirgu
  • Dec 1, 2022 10:43 AM UTC
Hi @david_r​ ,
By the way, I added AttributeEncoder transformer, before HttpCaller transformer, in order to change encoding, but it didn't work.
dxirgu
  • Dec 1, 2022 11:05 AM UTC
Hi @david_r​ ,
Hi @david_r​
thanks for your help. I've just tried what you propose but, unfortunately, it didn't work.
  • Dec 1, 2022 11:15 AM UTC
dxirgu
  • Dec 1, 2022 12:03 PM UTC
Thank you so much @david_r​, it works!!!
I'll try to reach out with our FME reseller to confirm this point.
peteralstorp
Forum|alt.badge.img+8
I also experience problems with the HTTPCaller 2022.2 and would appreciate a statement from SAFE regarding this problem - and if there are any workarounds.
peteralstorp
Scripts I could use in 2021 don't work anymore. Specifically I'm having a hard time updating JSON-chunks for items in ArcGIS Enterprise via the REST API...
  • Dec 6, 2022 3:09 PM UTC
Hi @mark2atsafe​ and @Mark Stoakes​  do you know if this is a known issue?
daveatsafe
Forum|alt.badge.img+24
  • Dec 7, 2022 4:52 PM UTC
Hi @dxirgu​,
This problem seems to have introduced between FME 2022.1 and FME 2022.2. I have created a problem report for our development team (FMEENGINE-75726), and expect to see a resolution in FME 2023.
I will notify you if we find a workaround, but you may want to replace your FME 2022.2 installation with FME 2022.1.
peteralstorp
Hi @dxirgu​,
@daveatsafe​ We update all our desktop installations at the same time, as well as FME Server and Cloud so downgrading is not an option. No sightings of a workaround?
dxirgu
  • Dec 22, 2022 10:14 AM UTC
Hi @dxirgu​,
Thank you so much @daveatsafe​ !!!
jovitaatsafe
Forum|alt.badge.img+11
Hi @dxirgu​, @david_r​, and @peteralstorp​,
I'm pleased to share that the problem report Dave filed above, (FMEENGINE-75726), has been resolved with a fix for FME 2022.2.2 and newer. You can find the fix in both the official and beta builds on our downloads page. Please let us know if you should have any feedback on it!
krisvesweco
  • Dec 8, 2023 7:05 AM UTC
Hey @jovitaatsafe​ . In what build number was this resolved? I have this exact problem on our FME Server, 2022.2 Build 22765 Win64 . Are there any known workarounds?
  • Dec 8, 2023 7:57 AM UTC
According to https://engage.safe.com/support/downloads/#past-versions, FME 2022.2.2 corresponds to build number 22782. There's a suggested workaround mentioned at the top of this post, i.e. removing the diacritics or replacing the problematic characters.
jovitaatsafe
Hi @krisvesweco​, the minimum build on the fix is build 22778, so it looks like your version is just below that if you'd like to upgrade or use ​@david_r​'s workaround of using the StringDiacriticRemover before the HTTPCaller.
saraatsafe
Forum|alt.badge.img+13
  • Dec 11, 2023 10:28 PM UTC
Hi @krisvesweco​, it looks like this issue was resolved as of build 22778. Would you be able to download and test out a newer build?
krisvesweco
  • Dec 14, 2023 2:53 PM UTC
Thank you for you input, @david_r​ , @jovitaatsafe​  and @saraatsafe​
Well, upgrading the FME server will take some time and planning unfortunately.
 I was hoping for a workaround that could be used that still makes us use the Swedish characters . If I cant set certain words with Swedish characters I cant upload to the service at all since it is required fields. So if I remove the diacritics the service will reject my json.
  • Dec 14, 2023 3:36 PM UTC
It brings me no joy to say this, but if you're completely stumped then it might be time to break out Python and the trusty "requests" module.
krisvesweco
  • Dec 15, 2023 10:40 AM UTC
Great, good idea @david_r​ ! I successfully built a workaround using requests and pythoncaller. I post some code here to help others that might experience this problem:
import fme
import fmeobjects
from pathlib import Path
import json
from fmewebservices import FMENamedConnectionManager
import requests
from requests.packages.urllib3.util.retry import Retry
from requests.adapters import HTTPAdapter
def requests_retry_session(
    retries=3,
    backoff_factor=0.3,
    status_forcelist=(500, 502, 504),
    session=None,):
    session = session or requests.Session()
    retry = Retry(
        total=retries,
        read=retries,
        connect=retries,
        backoff_factor=backoff_factor,
        status_forcelist=status_forcelist,
    adapter = HTTPAdapter(max_retries=retry)
    session.mount('http://', adapter)
    session.mount('https://', adapter)
    return session
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self, feature):
        connection_manager = FMENamedConnectionManager()
        connection_name = 'your_connection_name_to_use'
        connection_info = connection_manager.getNamedConnection(connection_name)
        headerToken = connection_info.getAuthorizationHeader()
        #fix tuple to dict
        headerToken = [headerToken]
        headerToken = dict(headerToken)
        headerToken['Authorization'] = headerToken.pop('Authorization: ')
        file_to_upload = feature.getAttribute('path_windows')
        url = 'https://your_url_to_rest_api'
        #create a dictionary
        data = {}
        data['name'] = feature.getAttribute('path_rootname')
        data['documentType'] = {}
        data['documentType']['name'] = feature.getAttribute('documentType')
        data['customFields'] = {}
        data['customFields']['Status'] = {}
        data['customFields']['Status']['value'] = feature.getAttribute('Status')
        data['parent'] = {}
        data['parent']['type'] = "folder"
        data['parent']['id'] = feature.getAttribute('folderID')
        encoded_data = json.dumps(data, ensure_ascii=False).encode('utf8')
        files = {
            'data': (None, encoded_data, 'application/json'),
            'file': (feature.getAttribute('WF_file_rootname') + '.' + feature.getAttribute('WF_file_extension'), open(file_to_upload, 'rb'),'application/octet-stream')
        successfulresponse = False
        try:
            WFresponse = requests_retry_session().post(url, files=files, headers=headerToken, timeout=10)
        except Exception as x:
            _http_status_code = 'Connection timed out, restarting application... ' + x.__class__.__name__ + ' ' + 'uploadNewFileWF'
        else:#code that must be executed if the try clause does not raise an exception
            successfulresponse = True
            _http_status_code = WFresponse.status_code
        feature.setAttribute('_http_status_code', _http_status_code)
        self.pyoutput(feature)
    def close(self):
        pass
    def process_group(self):
        pass
    def has_support_for(self, support_type):
        if support_type == fmeobjects.FME_SUPPORT_FEATURE_TABLE_SHIM:
            return False
        return False
  • Dec 15, 2023 10:58 AM UTC
import fme
import fmeobjects
import json
import requests
    retries=3,
    backoff_factor=0.3,
    session=None,):
    retry = Retry(
        total=retries,
        read=retries,
        connect=retries,
    return session
    def __init__(self):
        pass
        #fix tuple to dict
        data = {}
        data['parent'] = {}
        files = {
        try:
    def close(self):
        pass
        pass
            return False
        return False
Very nice, thanks for sharing!
