HTTPCaller returning 403 error
tnarladni
Forum|alt.badge.img+15
This is the URL i'm trying to access.
https://qpublic.schneidercorp.com/Application.aspx?AppID=1048&PageTypeID=4&KeyValue=450070160000
It's a public link. If I try to access it via the HTTPCaller, it throws a 403 error. Why would accessing the link via HTTPCaller throws an error? Thanks
Forum|alt.badge.img+49
Maybe it's blocked based on the user-agent, to prevent scraping the site?
thijsknapen
Forum|alt.badge.img+10
  • August 26, 2023
Well, the website seems to perform some kind of verification step (e.g. try it out in the incognito mode of your browser).
If I follow the traffic in the browser, I notice that also there the initial response is 403, but after some additional steps/requests (the verification steps), the result is returned.
I suppose if you would be able to mimic the verification steps in FME, you could make it work, but I think that may be quite difficult (I'm not able to help you much further with that).
Maybe you can use a PythonCaller that makes use of a Selenium module (?) for this. See also; Selenium
Selenium can be used to automate browser actions (I have mainly heard of it being used for testing (web) applications).
