HttpCaller: HTTP/FTP transfer error: 'SSL connect error'
I have been able to download file from this url: https://firms.modaps.eosdis.nasa.gov/data/active_fire/c6/kml/MODIS_C6_Canada_48h.kml in the past. Strangely, it does not work anymore. I am getting ssl connect error. Other than upgrading my FME Desktop from 2019 to 2020, nothing has changed.
Any assistance will be much appreciated.
Lawrence
virtualcitymatt
Forum|alt.badge.img+36
Of you turn on debug logging you miiight get a little bit more information. Another thing to try is to turn of certificate validation to see if that helps.​
nielsgerrits
Forum|alt.badge.img+54
I can reproduce his issue in 2019.1, changing HTTPCaller parameters does not seem to help, debug does not give another clue. Browser is downloading the file without a problem. Maybe submit a case?
  • August 21, 2020
Thanks for the suggestion. I will submit a case to Safe Support.
Forum|alt.badge.img+39
  • February 24, 2021
Did you discover anything more about this error @lawrence​
I seem to be encountering it intermittently when running a workspace on FME Server 2019
  • February 24, 2021
Regardless of FME version or platform, HTTPCaller doesn't seem to work in this case. Through Knowledge Base, I discovered there is an alternate transformer call AsyncHTTPCaller. It solves the problem for me.
