How to write file geodatabase output including feature dataset
  • May 29, 2023 2:29 PM UTC
  • 742 views
spiderman
Forum|alt.badge.img+7
Hello ,
i am using two feature reader one for oracle non-spatial and other feature reader for an Arcsde geodatabase
I would like to write the output in geodatabase including Feature dataset ,to use it later as input for ArcGis pro .
how could I achieve it ?
Fme 2021
thanks in advance
joepk
Forum|alt.badge.img+22
  • Sep 11, 2023 2:21 PM UTC
In the FeatureWriter transformer, select Esri file geodb as Format. You can specify a Feature Dataset in the fme_feature_type attribute under the 'Format Attributes' tab. I don't know how this is done with a regular writer.
Have a look at the documentation: https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/geodatabase/feature_dataset.htm
Hope this helps.
