How to use pythoncaller (getAttribute) in another function?
  • May 20, 2022 4:09 PM UTC
  • 124 views
Hello,
I'd like to use feature attribute in another function. something like
class FeatureProcessor:
  def __init__(self):
    pass
  def input(self, feature):
    col1 = feature.getAttribute('col1')
    col2 = feature.getAttribute('col2')
    self.pyoutput(feature)
  def close(self):
    pass
def myFunction(col1,col2)
another code etc.
I do not know how I can get attributes col1 and col2 to use it in another function.. (first time using python caller) .. thanks for help.
hkingsbury
Forum|alt.badge.img+73
  • May 22, 2022 8:34 PM UTC
With your second function, you need to call it (line 7), so something like:
  def __init__(self):
    pass
  def close(self):
    pass
    <do something>
  • May 22, 2022 9:38 PM UTC
  def __init__(self):
    pass
  def close(self):
    pass
    <do something>
Hello I  found a solution similar to that .. I wrote the function within the  def input function (nested function). But I will try your solution.. that would be easier.
Thanks for your answer
