How to sum attribute of all points in an area
  • Oct 26, 2022 9:33 AM UTC
  • 219 views
I have a point shp file that has an attribute with a number and I need to do a point on area overlayer, but the count in the area needs to be a sum of the attribute in the point file. I am stuck on how to do this! Hope this makes sense!
Forum|alt.badge.img+54
  • Oct 26, 2022 9:47 AM UTC
Under attribute accumulation in the PointOnAreaOverlayer Parameters you need to tick generate list on output 'Area', specify a name for your list and then select the attribute you need to sum. Then a ListSummer transformer after this to get the sum
f.kemminje
Forum|alt.badge.img+11
  • Nov 1, 2022 11:26 AM UTC
here is the w bench
