how to straighten line
  • Jan 25, 2022 1:15 PM UTC
  • 6 replies
  • 244 views
is there an easy way to straighten a line.
i have created a shortest route on a grid, now i want to straighten this line as it is indicated in the picture. best with 90 degree angle
thanks in advance
Best answer by takashi
Hi @sebastiangoerck​ , I think you can use the NeighborFinder to find the vertex of your desired right angle corner. See the screenshot.straighten-line-example
dustin
Forum|alt.badge.img+36
  • Jan 25, 2022 2:41 PM UTC
In theory....
  • Extract the start and end points of the lines using the Snipper transformer.
  • Using the BoundingBoxExtractor, extract the bounding box of each input line, and then use the GeometryCoercer to convert to line.
  • Using the PointOnLineOverlayer, split the bounding box line with the points from the Snipper. This should give you 2 lines from the lines output port.
  • Using the Snipper, snip off each end of the lines
  • Feed the 2 lines into the Candidate port of a SpatialFilter. The Filter will be the original line. From the Passed port should be the 'straightened' line.
chrisatsafe
Extracting the start and end points of the feature is definitely the easiest approach. You can also accomplish this with the CoordinateExtractor, ListElementCounter and 3 VertexCreators to recreate the line with a 90 degree turn. The attached workspace might help with this if you haven't already solved it!imageExample 1 (highlighted is the new line):
imageExample 2 (highlighted is the new line):
thank you for your support.
Your "90DegreeLineCreator" seems to be a good approach, but unfortunatly i cant use it with FME 2020 (we have this version on our server, so i have to use this one) and if i try it with 2021, then the result is not what i expected. the angle is on the wrong side, the angle must be on the same side as the origin line angle is (see attachment, blue line on the right side)
  • Jan 26, 2022 3:38 PM UTC
chrisatsafe
It's possible the lines we are comparing were drawn in a different order. If you swap the coordinates in the second VertexCreator that should do the trick (essentially changing which x/y axis to align to). Try setting it to this instead:
@Takashi Iijima​ your solution works perfect...thank you
there are always several ways that lead to the result, for me this method is best
thank you all for your time and your support!
