How to split one column to two columns ?
  • August 18, 2023
  • 102 views
spiderman
Forum|alt.badge.img+7
Hello ,
How to split the content of one column to two columns ?
my output of aggregator looks like string12-string56 at same cell in one column and all rows similar .
i would like to have two attributes one called base include string12 and other attribute called next include string56 and implement the method for all rows
Which transformer should i use ?how to use it ?
fme 2021
thanks in advance
Best answer by daveatsafe
Hi @spiderman​,
You can use the AttributeSplitter to split based on the number of columns or separator character. For more complex attribute splitting using Regular Expressions, you can use the Advanced options in the StringSearcher.
daveatsafe
Forum|alt.badge.img+19
  • August 18, 2023
Hi @spiderman​,
