How to split a bounding box when access a feature limitation number and loop it again and again
  • June 4, 2019
  • 62 views
azad456
I want to read features from a WFS service version 1.0 , which has a limitation of maximum 10000 features per call .
How to split my bounding box , when reaching the max number? It should loop the reading, unti I get all my features.
Best answer by redgeographics
You can split the bounding box using a Tiler, but I think the only feasible way is to iterate through it, if you reach the limit on one tile, split it 2 x 2 and try again and so on.
Forum|alt.badge.img+62
  • June 4, 2019
azad456
  • June 4, 2019
Thanks @redgeographics I looked at the Tiler transforme. I cant find where to define the nembuer of features for tiling and also how to iterate it??
