How to specify Feature Operation parameter in FME Objects Writer
  • Nov 2, 2015 12:25 PM UTC
  • 62 views
Hi
We have some java code that used FME Objects 2013 and we upgraded it to 2015. Some of our tests started to fail. When I investigated I found that in the log it says
WARN |MS SQL Server (Spatial) Writer: The fme_db_operation attribute value 'DELETE' on feature conflicts with Feature Operation 'Insert'. Rejecting feature
In documentation there is a description of Feature Operation parameter but I tried to specify it in various ways and it still didn't work. For example:
IFMEStringArray params = fmeSession.createStringArray();
IFMEStringArray directives = fmeSession.createStringArray();
params.append("Feature Operation"); // tried FEATURE_OPERATION etc.
params.append("fme_db_operation");
IFMEUniversalWriter fmeWriter = fmeSession .createWriter("MSSQL_SPATIAL", directives);
fmeWriter.open("fme_datastore_test", params);
fmeFeature.setStringAttribute("fme_db_operation", "DELETE");
fmeWriter.write(fmeFeature);
What am I doing wrong? It's hard to understand from documentation what actual parameter's name is ("Feature Operation"?) and how "format parameters" are passed to writers - as parameters in 'open' or as directives in 'createWriter'?
Thank you.
  • Nov 2, 2015 12:32 PM UTC
Hi
Have a look at this post regarding how to use the FMEDialog() class to show you the syntax for the different directives.
David
