How to setup arcgispro-py3-clone as preferred python interpreter.
markvv
I'm trying to run a python script that accesses python modules in an arcpy cloned environment. But I'm having trouble setting FME to use the conda python interpreter.
I have set the preferred python interpreter in the FME options to the cloned interpreter.imageHowever FME looks to default to the standard arcpy interpreter.
imageAnd returns the following error after running the workbench: Python Exception <ModuleNotFoundError>: No module named 'untools'
Also tried the following, but that does not seem to work:
import sys
sys.path.append(r"C:\Users\markv\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\python39.dll")
Python compatibility: Esri ArcGIS Python 3.9 - Would have liked to see the custom interpreter here, but it does not.
ESRI ArcGIS compatibility: Auto
Does anybody have any idea what I am doing wrong?
Thanks,
Mark
Best answer by rahulsharma
Hi @markvv​
You have set the "Preferred Python Interpreter" under Tools --> FME Options
Once you set the option there, you can override the value by setting the Python Compatability in the workspace under Workspace --> Parameters --> Scripting --> Python Compatability
ISSUE:
When you are setting python compatibility to "Esri ArcGIS Python 3.9" you are overriding the preferred interpreter(set under FME Options).
SOLUTION:
Set Python Compatability in
to FME Python 3.9+
Let me know if that works.
rahulsharma
Forum|alt.badge.img+10
  • February 7, 2023
Hi @markvv​
ISSUE:
SOLUTION:
to FME Python 3.9+
markvv
  • February 8, 2023
rahulsharma wrote:
Hi @markvv​
ISSUE:
SOLUTION:
to FME Python 3.9+
Perfect, this worked!
