how to separate having numerical value in street name?
  • January 27, 2020
  • 47 views
tomjerry.vl
Only identify indicated yellow color values is possible or not
NameIdentifyvenkat 25 rockvenkat 25 rockwinner 564 bufferwinner 564 bufferlock 57 fuzzylock 57 fuzzylime roadlime roadfantasy streetfantasy streetvennila roadvennila roadram nagar 56ram nagar 56ganga temple 90 ganga temple 90 suri nagar 45 suri nagar 45
Best answer by takashi
A Tester with this setting routes features having name containing one or more number characters to the Passed port.
  • January 27, 2020
bwn
Forum|alt.badge.img+26
  • January 27, 2020
An alternative is that you can also use StringSearcher.   This both tests the condition and extracts the substring.
Setting the Regular Expression similarly to how @takashi has it will get the answer:
Contains Regular Expression = \d+
Will get any numeric sequences of characters and output the number as the "Matched" attribute
Contains Regular Expression = \b\d+\b
Will get any numeric sequences of characters, but only those that are bound by a word boundary like a space character and output the number as the "Matched" attribute.
tomjerry.vl
  • January 27, 2020
TQ it's working
tomjerry.vl
  • January 27, 2020
it's working
