How to send through the value of zero if no features coming through...
  • June 9, 2023
  • 35 views
ingalla
Forum|alt.badge.img+10
I am trying to update a feature class containing statistics. Basically i am using the following fields
  • fme_basename
  • fme_featuretype
and each value from the fme_db_operation (insert, upsert, update, delete etc) is the number of each
my problem is, that if there are no deletes i get no features coming through as expected, but how can i still send through the fme_basename, fme_featuretype, and for example the value of zero for the delete attribute.
I want to be able to add the total records, but obviously can not do that if there is no value, hence setting as zero.
From what i have, if there are changes then they go through the workflow as expected.
Regards
Andy
nielsgerrits
Forum|alt.badge.img+55
Sounds like a job for the NoFeaturesTester from the FME hub.
