How to return value from Postgres procedure or function to SQL executor's Result port?
  • October 20, 2021
  • 596 views
f.kemminje
Forum|alt.badge.img+11
safeoct21I am renaming the Postgres tables inside the SQL executor(Postgres).
If the task is successful, I need a success mark or flag from the SQL executor(stored proc).
here there are two flags variables in my code ie "done2" and "i"
But the initiator only comes out, nothing comes from the output port.
I need one feature from Result port 1 for success or 0 for failure.
Can Anyone help me?
CREATE OR REPLACE FUNCTION func1()
  RETURNS integer AS
$BODY$
DECLARE
   cntold INTEGER :0 ;
   cntcur INTEGER :0;
   i INTEGER :0;
   BEGIN
        SELECT INTO cntold count(*) FROM @Value(table_name_old) limit 10;
        SELECT INTO cntcur count(*) FROM @Value(table_name) limit 10;
        --SELECT INTO cntnew count(*) FROM @Value(table_name_new) limit 10;
        IF cntold > 0 and cntcur > 0 THEN
            EXECUTE 'DROP TABLE @Value(table_name_old)';
            EXECUTE 'ALTER TABLE @Value(table_name) RENAME TO @Value(table_name_old)';
            EXECUTE 'ALTER TABLE @Value(table_name_new) RENAME TO @Value(table_name)';
            EXECUTE 'SELECT 1 AS DONE2';
            i=1;
            return i;
        END IF;
    END$BODY$
    LANGUAGE plpgsql VOLATILE
Best answer by david_r
I haven't tested it, but I suspect that your function has to return something that is table-like (rather than an integer) for FME to pick it up.
First google hit looks promising: https://www.postgresqltutorial.com/plpgsql-function-returns-a-table/
In your SQLExecutor you can then try
select * from func1()
I'm curious to hear how that works.
  • October 21, 2021
f.kemminje
  • October 21, 2021
@david_r​ I added One more SQL executor after the first SQL executor (create function), and pasted your string "select * from func1()". It worked David.
Thank you very much.
