How to resolve "ArcGIS Online Feature Service Reader: Could not find a Feature Service item matching the Feature Service directive"
  • Jan 19, 2021 6:25 AM UTC
  • 444 views
I have a survey123 application. i am trying to connect the feature class connected with this application in ArcGIS Online to my local database. For this i am using FME Workbench. I have previously conencted Arcgis online feature class using fme desktop and it worked fine. This time however i am getting the following error.
I am using FME 2020.1
When i added the AGOL reader and chose this feature class i am getting column names in reader which means it is able to connect to feature class, when i press the see source data on reader I can see the data as well. It gives me error when i run the FME even if i don't have any transformer and just inspector.
FMQ Q
Best answer by markatsafe
@smas1​ Can you share a log file & workspace (or send it to mark @ safe.com if the data is sensitive).
  • Make sure you do have read permission for you Feature Class - it definitely looks like you do.
  • are there any special characters in the feature class name (like a \\)
  • Jan 19, 2021 5:02 PM UTC
  • Jan 20, 2021 5:06 AM UTC
Hi @Mark Stoakes​
Sure I will share FME and log, though i need to check if i can share feature class publicly on AGOL. If I cannot I don't know how you will be able to see this.
FC name is "Operations Integrity Management/xxxxxxxxxxx Right of Way Surveillance "
and Layer name is "survey"
May be the issue is in the name ?
  • Jan 20, 2021 10:31 AM UTC
I have renamed and the issue is resolved. Either it was due to long name or name with space characters in it.
but it is resolved.
Thank you @Mark Stoakes​  for guidance.
