How to remove insterction point in line
  • Aug 12, 2023 8:30 AM UTC
  • 97 views
gogopotter90
Forum|alt.badge.img+14
I have self interaction in line .
line has id but it make circle and intersect itself .
how could I remove the intersection point at same line ?
my problem : after using intersection lines ,I found this line divide to 3 lines ,because it intersect itself in point .
will be possible to let intersector Transformator to create find intersection lines but between different id and ignore the intersection lines for line that has specific id .
Could I specific it in parameter ,to find intersection lines only for different id ?
Forum|alt.badge.img+63
Could you draw a picture of what you want to ideally get out of this? The Intersector will indeed split the line into 3 parts, but if I understand you correctly you want to retain it as a single line, but not have it self-intersect. So do you want it to cross instead of intersect at that point?
gogopotter90
  • Aug 13, 2023 12:46 AM UTC
U understood correctly .
i would like it to cross instead of intersect
2F01CD2B-498C-4536-8D65-D264B4A487EF.how could I achieve it ?
ctredinnick
Forum|alt.badge.img+22
  • Aug 14, 2023 3:57 AM UTC
It sounds like you could use a SpatialRelator, compare the whole dataset to itself, then exclude the instances where the ID matches.
So on the SpatialRelator, add to a list the IDs of every overlap, then explode that list, then test where IDs are different. You may be careful to exclude cases where lines meet/touch ends but don't overlap.
If you have lines and they loop back on themselves and you want to remove the vertex where the line crosses itself, you can use a Chopper (1 vertex), DuplicateFilter on X and Y, then PointConnector to rebuild the line
gogopotter90
  • Aug 14, 2023 6:20 AM UTC
Thanks for ur suggestion .i have attached image about my problem .
i have tested this method for one line crosses itself and it works
but I have still question should I do this method for all lines that crosses itself by using spatial realtor predicate crosses then ur method
what i have did till now
i would like to remove the vertex where lines crosses .
so i did as u suggested for one line and used chopper ,then matcher ,
output port : not matched point are points
but I have to reorder points first so I have added counter. After chopper and at end line builder .
i have build the line again without cross vertex .thanks a lot ,it works great
