How to read/write ODS files? Thanks
  • November 17, 2020
  • 135 views
farfar
Forum|alt.badge.img+11
  • November 17, 2020
@farfar​ are you referring to Apache OpenOffice suite spreadsheets?
farfar
  • November 18, 2020
Yes.
and using fme desktop for windows.
  • November 18, 2020
@farfar​ Sorry - at this point FME doesn't support Open Office. Please vote on this Idea and add any comments on your use case.
OpenOffice Calc does support export to Excel XLSX format and FME can read that. Also, ODS is based on XML, so perhaps FME's XML reader might be able to return the data you need, but that is obviously a more complicated approach.
Hi, you should use LibreOffice or OpenODS. Both run great with this type of file.
