I have downloaded FME 2020 software into my D drive and I have moved my FME 2020 Data into my D Drive as well. So I started with exercise 1.1 Begin but every time I hit the "RUN" button, I would get errors saying "Cannot open dataset `C:\\FMEData2020\\Data\\Boundaries\\LocalAreas.kml' because it keep reading it from the C drive, so how do I get it to read it from the D drive cos I have already moved the FMEData2020 into the D drive. The reason for moving is I don't have much space in my C drive. Any suggestions, please?
Writers have a similar setting. At least some of them. You will discover further along that some writers are different from others.
