How to read a shapefile inside a zip file (in two levels)
  • Apr 11, 2022 12:17 PM UTC
  • 258 views
I have to read several shapefiles that are in a second level zipped file. As an example:
C:\\compressed1.zip \\compressed2.zip\\ layer.shp
I get to reach the first level but when I try to reach the second level, FME gives me failures.
Any idea? Thank you very much
Best answer by nielsgerrits
Not sure if this can be done with a Reader/FeatureReader but you can use the ZipExtractor from the FME hub to achieve this.
"If you set "Yes" to the "Unzip Nested Zip Files Recursively" parameter, this transformer unzips all the nested zip files recursively."
nielsgerrits
Forum|alt.badge.img+67
  • Apr 11, 2022 1:03 PM UTC
  • Apr 11, 2022 6:08 PM UTC
It's not exactly what I want to do, but your review is a great help and with a Tester I've managed to do it.
Thank you very much for your help.
