How to publish data on ArcGIS Online via FME workspace?
  • May 9, 2023 9:21 PM UTC
  • 91 views
jaygrg111_
Forum|alt.badge.img+9
I have workspace that reads data from SDE, does some attribute changes; ESRI ArcGIS Online Feature Service writer that writes data on ArcGIS Online. But its not working. Any suggestion is highly appreciated.
saraatsafe
Forum|alt.badge.img+13
  • May 16, 2023 7:00 PM UTC
Hi @jaygrg111_​, are you able to provide more details? Are there any errors or warnings that pop up that could give us some clues as to what's happening? If you're able to share your workspace and/or log file that would be helpful as well.
jaygrg111_
  • May 16, 2023 10:16 PM UTC
Hi @saraatsafe​ , thank you for your response. I solved it. There was an authentication issue. Thank you so much!
