how to get cross line on polygon?
  • Jul 13, 2022 8:12 AM UTC
  • 200 views
spiderman
Forum|alt.badge.img+7
i have lines and i have polygon
my question that i would like to find which line intersects with polygon and which lines crosses with polygon
so i have transformed polygon to lines by geometry coercer then i used spatial filter ,predicate crosses
and another time i used spatial filter with predicate intersect
but i have found that the output in passed port even if i have chosen predicate cross or intersect ,i get this line in output
why did this line appear when i choose predicate intersect ,because no intersection point between line and polygon .
i would like to have it only when i use predicate cross .
i hope someone has idea for me
FME 2020question
Best answer by geomancer
Now if you want to test for vertices in common, you can do a SpatialFilter on the vertices, like this.
Common_Vertices
geomancer
Forum|alt.badge.img+71
  • Jul 13, 2022 9:07 AM UTC
You misinterpret 'Intersect'. Objects intersect when they are 'Not Disjoint', see Spatial Relations Defined. So when two objects cross, they also intersect (but not necessarily the other way around).
Also you don't have to coerce your polygons into polylines to test for intersection (or crossing).
spiderman
  • Jul 13, 2022 9:37 AM UTC
why did they consider as intersect object also ,if they have not intersection in point between both of them ?
geomancer
  • Jul 13, 2022 9:44 AM UTC
Common_Vertices
geomancer
  • Jul 13, 2022 9:46 AM UTC
When objects are not disjoint, they intersect. Look at the definitions in Spatial Relations Defined.
