How to find which number closet to other number ?
  • August 30, 2023
  • 69 views
spiderman
Forum|alt.badge.img+7
Hello
how to find which value closet to another value ?
i have 4 id
id -value
1 - 15
2 - 40
3 - 70
4 10
how could I find which value of id closet to another value of another id more than others .
As example , my target to know that
id 1 and id 4 are close to each other
and id 2 and id 3 ,close to each other
fme 2021
DanAtSafe
Forum|alt.badge.img+21
  • August 30, 2023
Hi @spiderman​ I'd make the values into a number line with a VertexCreator, then use a NeighborFinder to find the point closest to itself. From your sample data you'll see that Id 1 is the closest point to both Id's 2 and 4.
If you want to make pairs of closest points so that for the entire set of points the sum of the distances between paired points is minimized - then that would be very difficult to solve.
closest_point
spiderman
  • August 31, 2023
closest_point
Thanks for ur reply.
but is there any mathematical calculation to calculate the difference between values
to say 15-10 = 5 so id 1,4 are close
but I think ,I have to calculate the difference between all id .
i believe ,by using neighbor finder will not be possible to get the solution that I want .
DanAtSafe
  • September 1, 2023
I'm not sure of what you want exactly. Here's another method using lists. The trick is to get the values of all other features onto the current feature. The workspace does that with an Aggregator, Deaggregator, and ListExploder. But first it copies the current features attributes to traits. The Tester currently causes the output to have just one record (with the distance value) for every combination of input features. Change the ">" to "!=" to get duplicates, but reversed, e.g. distance from id 1 to id 4, and the distance from id 4 to id 1.
nielsgerrits
Forum|alt.badge.img+64
How about sorting on Value and group record 1&2, 3&4, 5&6 using an AttributeCreator and Adjacent Feature Attributes?
