How to find the source data geometry type is annotation or not?
  • August 10, 2022
  • 69 views
ranga_tolapi
Forum|alt.badge.img+9
FME Desktop version 2022.1 (64-bit)
How to find the source data (a feature class from Personal Geodatabase or File Geodatabase) geometry type is annotation (ArcMap or ArcGIS Pro based) or not?
  • August 10, 2022
Did you look into using the GeometryFilter, set to filter for Text?
ranga_tolapi
  • August 13, 2022
@david_r​ This is working fine with File Geodatabase format. However, this is not working for Personal Geodatabase. Please refer to the enclosed screenshot.
  • August 15, 2022
If you believe this to be an error, you should probably contact your FME reseller or Safe support for assistance. But do keep in mind that the Personal Geodatabase format is on its way out and isn't supported in 64-bit ArcGIS, which I would assume also carries over to 64-bit FME, see https://pro.arcgis.com/en/pro-app/latest/tool-reference/tool-errors-and-warnings/001001-010000/tool-errors-and-warnings-01301-01325-001324.htm
I'm mentioning this since the bookmark in the screenshot above indicates 64-bit FME.
