How to fill a hole in a raster DEM
  • Aug 3, 2020 4:17 PM UTC
  • 5 replies
  • 375 views
btl
Forum|alt.badge.img+12
I'm trying to replace part of a raster DEM so I cut a hole in it and created a few points in a shapefile to define new heights in the hole - I want to interpolate across the hole to these new heights keeping everything else the same.
I'm using RasterDEMGenerator but the hole is filled with elevation=0 except for tiny spikes where my control points are
Forum|alt.badge.img+63
How do you have the RasterDEMGenerator set up? And how does the spacing of the new points relate to the DEM spacing?
btl
  • Aug 4, 2020 8:16 AM UTC
I'm working in degrees so:
  • Output X and Y spacing = 5 * 10^-5 (the spacing of the original raster)
  • Surface tolerance - I have tried large and small numbers, seems to make very little difference
  • Interpolation method - tried all three, mostly left on AUTO
  • No data value - left blank
I have 3 control points and I'm trying to use them to interpolate across a hole, which is maybe around 500 cells cut from the original dem - as shown in the pic below.
pic
Thinking out loud here, how about generating a TIN first of the original DEM and the control points and then create a new DEM from that?
btl
  • Aug 4, 2020 2:18 PM UTC
OK. The problem is when I cut the hole - it's creating values at zero, not nulls. So I just need to filter these out before channelling everything into RasterDEMGenerator.
lefred06
Forum|alt.badge.img+10
  • Aug 6, 2020 6:23 PM UTC
If your initial DEM is already a Raster, you might have to set a nodata value on this initial DEM (the one with the hole) to prevent values from the "hole" to be considered as "real" values.
