How to extract overlapping geometries
  • Oct 26, 2021 4:07 AM UTC
  • 107 views
Hello Sir/ Madam,
I am trying to check if the input "units" and within " floors".
​There are two floors and many units, which they both have "base level" attribute.
The following are what I would like to find out separately.
1) units that are completely outside of each floors
2) units that touch the floor boundary yet part of the portion is outside the floors
I am not sure how to do ​let FME know how to process each baselevel ( 4.53 and 10.3) in this case one by one.
The attached documents are in shapefile. I also attached my fmw in here.
Could someone please tell me what I did wrong?
Thank you in advance. 🙂
Zach
Best answer by jonathanklarup
Hey Zach,
I'd do it so :
Spatial filter
Floors as filter
Units as Candidate
1) "Filter is OGC-Disjoint From Candidate" = All units will fail cause none are completely outside of each floors
2) "Filter OGC-Contains Candidate" might do the job, if units are not contained by the floor, they have a portion outside..
2) could also be clipper and see if there are remnants.
Process each baselevel would be:
check off the Group Processing and Group by baselevel.
jonathanklarup
  • Oct 28, 2021 11:47 AM UTC
Hey Zach,
I'd do it so :
Spatial filter
Floors as filter
Units as Candidate
thank you very much! Will try it soon! :)
