How to extract/ generate the coordinates of intersection points of a line intersecting an area
  • Mar 2, 2021 12:41 PM UTC
  • 278 views
Dear FME community,
I have an important question concerning the FME workbench. I would like to know how one can extract the coordinates of the intersection-points of a line intersecting an area (a mesh with poligons). The coordinates of the intersection-points should have a maximal precision.
To give you some more information about my problem I have attached some screenshots.
screenshot_fme_01
here you can see a part from my workbench. Basically I just want to somehow combine the mesh and the lines and then extract the intersection points.
screenshot_fme_02here you can see the lines I was talking about above and the 3d-mesh. Now each line intersects the mesh at some point. I want to receive the coordinates of these intersection-points.
I would be very thankful, if you could provide any information on how to solve this problem. If you need any more infos, just let me know :)
muzhnasto
Forum|alt.badge.img+12
  • Sep 22, 2021 7:49 AM UTC
Hi, convert the lines into points and put them on the surface using Surface Draper
