How to extract coordinates of start and end line and get the relates id of each point (start/end)
  • Dec 1, 2023 2:48 PM UTC
  • 9 replies
  • 1102 views
gogopotter90
Forum|alt.badge.img+14
Hello ,
i am confused in my workspace .
i would like to extract the coordinates of start point and end point of the lines .
So I used coordinates extractor index 0 , and other coordinates extractor index -1 .
so I got the coordinates .
but how I know , this coordinates belong for which point id ( I mean which side of line is start and which side is -the end ) and depends on what ?
my target to get the coordinates and the relates points id to it .
I would like to get theses attributes
ID line | id point start | coordinates (x)start | coordinates (y) end | id point end |coordinates (x) end |coordinates (y) end
as example .
see picture , I need to extract the coordinates of each line ( start and end ) and know which id of the point that relates to this coordinate
Fme 2021
Best answer by takashi
This is was my problem .
i have did what u do before but I was so confusing .
I have the points id ,you are right
i will exapling in Details .
i know the start point id and end point id
and I have added a list on the line
so the line has now more details ,about the point that it connects with .
id line , id point a ,id point b
later after I use 2 vertex creator and find points by neighbour finder .
how to merge them with 2 point id at the same Line ?
i am really confusing about it .
Bcs as example
i have 3 end line ( points id ) are the same id .
so when I do merge May be ,coordinates go to wrong line .
when the id is the same .
(the id is same at some end lines Bcs I have used buffer and cut the lines that connect together in one point
so instead of one point ,I have different point include same point id .
please , id U can provide me with temperate solution .or screenshot ,will be better for me to get clear ur solution .
thanks a lot in advanc
Good to hear the workflow helps you.
You can avoid overwriting the same attribute names by setting Prefix Supplier to the Accumulation Mode parameter and set an appropriate prefix to the Prefix parameter, in the FeatureMerger.
Please check again the screenshot I posted.set-prefix-with-featuremerger
Forum|alt.badge.img+63
Just to clarify: you have those id points already, correct?
If that's the case you can use 2 VertexCreators to create the actual start and end points of the lines from your attribute values, then a NeighborFinder to match them with the id points. Then you have to bring it all back to the original lines again (FeatureMerger for example).
gogopotter90
  • Dec 1, 2023 9:08 PM UTC
Bcs as example
  • Dec 1, 2023 9:18 PM UTC
Bcs as example
HI @gogopotter90​ ,
Do you have point features each of which has point ID as its attribute? If yes, does a point exactly match start or end of a line?
gogopotter90
  • Dec 2, 2023 4:19 AM UTC
Bcs as example
Yes.
I have point id and it matches sometimes exactly the start or end of line
or it is close from the start or end of line and I have to use neighbour finder to find (which point of start /end line close to ) .
  • Dec 2, 2023 5:08 AM UTC
Bcs as example
I think ToplogyBuilder helps you to transfer attributes of point feature (point ID, x-coordinates and y-coordinates) to the lines.
Try the workflow shown in the attached screenshot. Probably you will have to set an appropriate value to the Tolerance parameter in the TopologyBuilder.topologybuilder-exampleAdditionally, if you would like to make coordinates of all the end nodes of lines exactly match the points, you can use AnchoredSnapper to do that before TopologyBuilder.
  • Dec 2, 2023 5:28 AM UTC
Bcs as example
This is an example using AncheredSnapper
topologybuilder-anchoredsnapper-example
gogopotter90
  • Dec 4, 2023 8:41 AM UTC
Bcs as example
Thanks a lot .
it works great , I needed only to add rename after first feature merger for point id and coordinates .because the result has overwritten on same name of point id so I added rename but it works great .
  • Dec 4, 2023 11:21 AM UTC
Bcs as example
gogopotter90
  • Dec 5, 2023 5:06 PM UTC
Bcs as example
Thanks a lot ,I have seen it now
