How to extract attributes from nested GeoJSON
  • Feb 25, 2021 1:31 PM UTC
  • 8 replies
  • 185 views
Picking any country from https://osm-boundaries.com/Map >download tick all_tags gives this in FME
FME01However in attribute manger I can only see the 7 input attributes
The all_tags looks like thisAll_tagsWhat I'd like to do is extract the non "name" tags as unique attributes
E.G. is_in, ISO3166-2, wikkidata etc.
Some of the tags are like is_in:country : VALUE
and keep the rest as a JSON string (keeping the values as is maintaining diacritics)
Some features have more unique tags than others so my output PostGIS table will have all possible columns and any feature with out a particular tag should be a NULL string
I can then write to a PostGIS database
Can someone tell me how to extract the all_tags JSON string as described?
danilo_fme
Forum|alt.badge.img+58
  • Feb 26, 2021 12:53 AM UTC
Hi @geo_geek
Could you share the Workspace template ( .fmwt )?
Thanks in Advance,
Danilo
  • Feb 26, 2021 8:46 AM UTC
@danilo_fme​
I attach Workspace template ( .fmwt ) as requested
danilo_fme
  • Feb 26, 2021 5:17 PM UTC
@danilo_fme​
Thanks @geo_geek​ . Could you sned me ( please ) the reader too?
  • Mar 2, 2021 9:16 AM UTC
Hi
Not totally sure what reader your asking for
On the reader => properties => help it points to
GeoJSON (Geographic JavaScript Object Notation) Reader/Writer
https://docs.safe.com/fme/2020.2/html/FME_Desktop_Documentation/FME_ReadersWriters/geojson/geojson.htm
This has the option of flattening all_tags to columns but as each data set has different tags this isn't of use I need a more dynamic method
caracadrian
Forum|alt.badge.img+23
  • Mar 2, 2021 2:49 PM UTC
Hi
@danilo_fme​ is refering to the .json file you downloaded from osm-boundaries.com.
We don't know if we need to be logged in to download or there is a trick to it but the download button isn't active.
  • Mar 2, 2021 4:40 PM UTC
OK
to enable DL you have to have a free Open Street map account and authenticate with that
I attach Thailand.geojson.gz as this has enough variety in the all_tags string other countries have more properties
Please note in order to upload I had to create a zip file this might need unziping
  • Mar 2, 2021 4:45 PM UTC
Sorry zip file attached hopefully other format wouldn't upload
danilo_fme
  • Mar 3, 2021 7:36 PM UTC
Thanks @geo_geek​ your data.
