How to explode polygon that contains arcs and lines?
  • Jan 30, 2021 8:26 PM UTC
  • 461 views
I would like to explode a polygon containing lines and arcs into its parts and preserve the arcs. I am reading an autocad drawing and I tried the chopper transformer but it chopped the arc into line segments which is not what I need. Has anyone done this before?
Best answer by warrendev
@garydlester​ , try setting the geometrypartextractor to the settings pictured in the attached image. I just changed the "Part to Test" to "This Part" in your workspace and was able to extract the arc.
arc_extract
warrendev
Forum|alt.badge.img+28
  • Jan 30, 2021 11:17 PM UTC
arc_extract
tomf
Forum|alt.badge.img+31
  • Jan 31, 2021 7:56 AM UTC
I've had success with the PathSplitter to break polygons into lines and arcs.
