How to establish multiple connections at the same time?
  • May 18, 2023 5:58 PM UTC
  • 506 views
esalmagul
Is there a shortcut to creating the connections automatically instead of dragging and connecting readers to writers one by one?
connections
dustin
Forum|alt.badge.img+36
  • May 18, 2023 6:52 PM UTC
You can use the Generate Workspace option, which will automatically bring in the the readers and writers already connected.image
esalmagul
  • May 18, 2023 7:08 PM UTC
That's great!
What is they all coming from multiple data sources?
evieatsafe
Forum|alt.badge.img+28
  • May 18, 2023 9:40 PM UTC
@esalmagul​ you can also enable Feature Type Connections in View > Windows > Feature Type Connections to quickly connect different feature types and transformers. Hope this helps!image
jimmy-james
Participant
  • Participant
  • May 18, 2023 9:45 PM UTC
There is a quick trick that might be usefull also that I found on the FME training, this is the example:
exampleThis connects PublicArt to all of the neighborhood reader feature types by clicking on the red triangle going into PublicArt, holding down the CTRL key (⌘ or Shift on Mac), and clicking on each triangle coming out of the neighborhood feature types (Downtown, Mount Pleasant, Strathcona, Fairview, Kitsilano, and West End).
