How to design pdf that include tables as excel file ?
  • November 23, 2023
  • 131 views
gogopotter90
Forum|alt.badge.img+13
Hello ,
i would like to design pdf that contains many tables look like excel file and these tables will filled in with some attribute names and some values
Fme 2021
Forum|alt.badge.img+49
There's a few suggestions here: https://community.safe.com/s/question/0D5Dm00001L6YBPKA3/how-to-write-attributes-into-pdf-report-
Long story short: you need to generate a point text feature for every cell and position them in the proper spots. Writing nice tables to PDF is, to put it bluntly, a hassle.
gogopotter90
  • November 24, 2023
Thanks
i have read it but will be possible to create a template of pdf then use FME to write the text as point directly in tables .
something else to understand better , if I need to create tables in pdf .
it means to create box with coordinates and try to locate them wisely in pdf page formatter .
what is the best method create tables quickly in Fme from your experience?
thanks for your help
