How to create relates, shp and excels that get written in to attribute named folder?
  • May 19, 2021 12:43 AM UTC
  • 40 views
  • PL.shp with attribute 1
  • Excel with Attibute 1 and Attribute 2
  • Attribute 1s relate
I have AttributeFilter set for Attribute 1 to extract Attirbute 1 from PL.shp
I need to relate Attribute 1 to Attribute 2, which was not in PL.shp, but is in a related Excel
Once the relate is attained from 1 and 2, I need to create a shp that retains the name of Attribute 2 which is then written into a folder with Attribute 2 name.
This will have to be done 200 times, so how can I efficiently get from reader to writing 200 shps that need to be in attribute 2 named folders?
Then from there, the shp needs to be created into an excel that is placed in attribute 2 named folder.
Best answer by caracadrian
Use FeatureJoiner or FeatureMerger to join the 2 datasources.
Use Fanout Database on the writer, click arrow down button and select Open Text Editor. Add "\\@Value(Attribute2)" and click OK .
fanoutSet the Writer to Shape Name: Attribute 2 (from attribute value dropdown list).
shape_namePS Check if the attribute values used contain invalid characters for folder and filenames.
caracadrian
Forum|alt.badge.img+23
  • May 19, 2021 10:01 AM UTC
