How to create new web connection for FME server?
  • Feb 10, 2021 4:52 AM UTC
  • 93 views
Just installed FME server and need to create new web connection.
Where do I create new user name and password?
Best answer by tomf
You need to create the users in FME Server before you can create a web connection using a new user. See
http://docs.safe.com/fme/html/FME_Server_Documentation/WebUI/User-Management.htm and linked pages for details.
Without performing any user set up there are the default users available: admin, author, user, guest, which have the same password as username (except admin if you changed it on first log-in as admin)
To use Windows Credentials you will have to configure FME Server to enable Single Sign-On http://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/IWA.htm
  • Feb 10, 2021 4:53 AM UTC
FME serverShould I click 'use windows credentials'?
tomf
Forum|alt.badge.img+31
  • Feb 10, 2021 5:05 AM UTC
  • Feb 10, 2021 9:51 PM UTC
Thanks that works
