How to copy attributes from one layer to another after spatial joining?
  • Apr 17, 2023 3:16 PM UTC
  • 171 views
claireco
Hello
I'm doing a spatial join between a polygon layer and a point layer. For polygons that are "passed" I want to retrieve the attributes of the corresponding points.
Wich transformer should I use ?
Thanks
dustin
Forum|alt.badge.img+36
  • Apr 17, 2023 4:06 PM UTC
You could use the PointOnAreaOverlayer. Under Attribute Accumulation, you can choose to merge attributes or create lists on the output features.
