I have about 3000 jpg and their coordinates in CSV format, I want to join the jpg and their respective coordinates saved on csv and create a ECW or Geotiff file
how can I do this
how can I do this
thanks for prompt reply , I tried database joiner and also feature joiner I so far not lucky in both of them , it could be the way how I have formatted the csv file or the setting within these transformer , can you give me a snap shot or more explanation of the above?
thanks
thanks
How are the jpg files referenced in your csv file?
e.g. if you have a column called Name which is the name of the jpg, you can expose the fme_basename and then in a FeatureMerger use the fme_basename as Requestor and Name as Supplier
thanks
Thanks you are a Star , it works
thanks alot
