How to convert a polyline with many sections into a single polyline
  • Aug 11, 2020 10:37 PM UTC
  • 357 views
nicholas
Forum|alt.badge.img+14
I have a MapInfo dataset of polylines where each polyline is composed of many sections (this is the MapInfo term). I want to convert to a clean polyline with only one section. What transformer can I use? I only want to combine the sections within each polyline, not between polylines.
deanhowell
Forum|alt.badge.img+24
  • Aug 11, 2020 11:47 PM UTC
Hello @nicholas​ I would suggest the LineCombiner transformer https://www.safe.com/transformers/line-combiner/
jdh
Forum|alt.badge.img+41
  • Aug 12, 2020 9:55 PM UTC
If I understand correctly you have a multipart path (polyline) features comprised of multiple segments (FME term) in which case you'll want to use the custom transformer PathSegmentJoiner.
