How to calculate line on area percent overlap?
  • April 14, 2023
  • 123 views
esalmagul
I have a case where I need to determine which wells (polylines) belong to which unit (polygons) based on spatial relationships.
I need to be able to know the percentage of those relationship (wells and units) and some key data associated with the unit. I need to determine percent of overlap and produce two outputs.
One to show only the relationships (between wells and units) with the highest percent of overlaps (including their percent overlap value) and an another containing all relationships (between wells and units) and their percent of intersect. Thanks!
danilo_fme
Forum|alt.badge.img+53
  • April 17, 2023
Hi @esalmagul​
Please, could you share your data?
londa
  • April 18, 2023
yes ,could you please share the data so that we can answer your querry.
esalmagul
  • April 25, 2023
Hi @esalmagul​
Here it is! Thanks! Wells are lines and units are polygons. Sometimes the same well crosses multiple units.
esalmagul
  • April 25, 2023
