How to avoid the file geodatabase from creating objectid_1
  • Jun 10, 2023 4:44 PM UTC
  • 218 views
spiderman
Forum|alt.badge.img+7
Hello ,
i am working with file geodatabase then writing the output into file geodatabase
so my input :file geodatabase and it contains ObejctId
but when I write the output into file geodatabase after finish work on the data .
i have found that the output contains new attribute called objectid_1
how to avoid the data from creating the new objectid_1
because I have already attribute Name called objectid and I do not need extra .
fme 2021
thanks in advance
  • Jun 12, 2023 8:37 AM UTC
Make sure you haven't defined a user attribute named "OBJECTID" on your writer (it will be created regardless).
If you use dynamic schema, also add "OBJECTID" to the list of attributes to remove from the dynamic schema definition.
spiderman
  • Jun 14, 2023 6:10 PM UTC
objectid, i have removed it from writer but it creates still object id
and I have tried and write dynamic and Remove it from list as you described but also It is still creating in output file geodatabase .
do you have other idea that I can do ?
could you upload sample workspace to remove object id ?
  • Jun 15, 2023 8:03 AM UTC
Can you please upload a minimal workspace of yours that demonstrates this issue, and that allows us to reproduce it.
