How to add external data to a Server App ?
  • Feb 25, 2022 9:12 AM UTC
  • 7 replies
  • 162 views
Hello,
When I open my app with the URL, I want to integrate external data (like local files) and run the processing but when I run it, an error message is displayed.
Thanks in advance
  • Feb 25, 2022 10:03 AM UTC
Hi @lachichi_farah​ , do you mean that the workspace need to use data read from a specific file saved somewhere in the FME Server?
Yes, the data I integrated when I created the processing on FME workbench. I can't integrate any other data.
  • Feb 25, 2022 11:57 AM UTC
A possible way is to upload the file (e.g. "resource.csv") into a subfolder (e.g. "my_folder") under the Resources/Data of the FME Server. You can then access the file from a workspace with this file path string.
$(FME_SHAREDRESOURCE_DATA)my_folder/resource.csv
Here, FME_SHAREDRESOURCE_DATA is one of pre-defined FME Server Parameters, which will be interpreted path to the Resources/Data folder with FME Server, an empty string with FME Desktop.
Thanks for helping but I want to put external data when I open the app with the Url without put my file in FME Server before. But even by this way it doesn't work. When I run the processing it displays: "There was nothing to download as the workspace didn't generate any output."
  • Mar 2, 2022 5:41 PM UTC
Sorry, I'm unclear the requirements. Are you looking for a way to upload a file to FME Server through the app interface?
Yes !
  • Mar 3, 2022 2:09 PM UTC
Create a workspace having a published user parameter (file type), and add:
Creator: Kick off the translation.
ParameterFetcher: Assign the parameter value (uploaded file path) to an attribute named "filecopy_source_dataset".
File Copy Write: Move the uploaded file to your desired location.
You can then run the workspace above as a Server App to upload a file to the server.
