How to add data to new field ?
  • Jan 30, 2020 10:20 AM UTC
  • 5 replies
  • 321 views
geo-x
Hello everybody.
I'm using FME for create an object with the transformer AttributeManager, but I would like to add values in each new field. Whait i the good transformer for that ?
Thanks for your help.
oscard
Forum|alt.badge.img+23
  • Jan 30, 2020 10:26 AM UTC
The AttributeManager has a column named "Value". There you can add value to each of your new fields.
geo-x
  • Jan 30, 2020 10:30 AM UTC
Yes but only one data per column no multiple values
oscard
  • Jan 30, 2020 10:40 AM UTC
We are going to need more info to help you. Does that value depend on the value of another field? Otherwise, you will need to merge your current data with the source of those values.
geo-x
  • Jan 30, 2020 10:48 AM UTC
No, it's only new values.
For exemple, I've a CSV file like this :
code | libelle
30 |zehfuzufeh
40 | zujzjedodizje
I create the fields code and libelle and after I need to integrate the informations.
oscard
  • Jan 30, 2020 11:00 AM UTC
code | libelle
30 |zehfuzufeh
40 | zujzjedodizje
Then I guess you need to add your CSV to the workspace using the CSV Reader.
Instead of using an AttrbiuteManager, you have to merge your data with the data from that CSV using a FeatureJoiner or FeatureMerger. That is possible if both source of data have a field or a combination of several fields in common.
