How do I connect FME to MongoDB?
  • Oct 11, 2021 10:12 PM UTC
  • 179 views
Hi, I'm new to MongoDB, and I'd like to use FME to import data into it. Can someone please provide me with an example that shows how to set up the connection, specifically the connection Name, Connection Type, Protocol, Host, Port, Database Name, Name and Value parameters?
Harry
danilo_fme
Forum|alt.badge.img+58
  • Oct 11, 2021 11:05 PM UTC
Hi @petrus451​
There are interesting links about this format here:
https://community.safe.com/s/global-search/%40uri#q=MongoDB&sort=relevancy&f:@commonsource=[Documentation,FME%20Community]
Thanks in Advance,
Danilo
  • Oct 12, 2021 12:11 PM UTC
Hi @petrus451​
Thanks in Advance,
Danilo
Thanks, Danilo. In case anyone has this question again, here's the configuration for the MongoDB writer:
Name: chose a unique name, e.g., myMondoDBWriterTest
Connection Type: Parameters
Protocol: Use the default, which is mongodb://
Host: localhost (assuming you're running it on your own machine)
Port: 27017
Database Name: the name of your database (not a collection), e.g, myJSONdatabase
