How do I add clothoids (spirals) to a geometry?
  • Sep 28, 2022 10:44 AM UTC
  • 10 replies
  • 198 views
mariaka
Forum|alt.badge.img+15
Hey there,
I need to transform a CSV-formatted file containing Geometry assignments into LandXML. Therefor geometry describing/containing clothoids need to be clothoids in the LandXML. They can be at the start, in the middle or at the end of a (line) geometry. I know how to create linear geometry (VertexCreator) and arc geometry (2DArcReplacer). But clothoids? 🤷‍♀️
Best answer by nielsgerrits
You can create a clothoid using a Creator transformer.
As an extra you can use a GeometryExtractor (encoding FME XML) to get an XML describing the parameters:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<geometry>
<clothoid>
<startCoord x="0" y="0"></startCoord>
<endCoord x="-0.27390607603951506" y="1.0140946349460176"></endCoord>
<localStartCoord x="0" y="0"></localStartCoord>
<startDirection>0</startDirection>
<startCurvature>1</startCurvature>
<endCurvature>2</endCurvature>
<length>3</length>
</clothoid>
</geometry>
Next you can edit these parameters in the XML and recreate the geometry from XML using the GeometryReplacer.
nielsgerrits
Forum|alt.badge.img+67
  • Sep 28, 2022 10:55 AM UTC
<geometry>
<clothoid>
<length>3</length>
</clothoid>
</geometry>
mariaka
  • Sep 28, 2022 10:58 AM UTC
So the Creator is just a "helper transformer" to get the XML description?
nielsgerrits
It can have different functions, but I use it to generate geometries like these or initiate FeatureReaders.
  • Sep 29, 2022 3:43 PM UTC
I'll just add that you can use the PathBuilder to join polylines, arcs and clothoids into a single line geometry.
mariaka
  • Oct 13, 2022 3:09 PM UTC
Screenshot LineCombiner LogBut PathBuilder closes the geometry. How can I prevent this? LineCombiner throws an error when connecting all the lines, arcs and clothoids.
  • Oct 13, 2022 3:23 PM UTC
Can you show us a screenshot of the result returned by the PathBuilder, as well as a what you would like to have?
mariaka
  • Oct 14, 2022 7:15 AM UTC
Sure, first picture: single line feaures [7]
Screenshot unjoined Lines
Second picture: one closed path
Screenshot PathBuilder
My allover goal is to create the geometry from a data format called XTR (TopoRail - from Swiss Federal Railways SBB). The geometry is defined with parameters for lines, arcs and clothoids (aka curves, spirals). Besides the problem of connectiong single lines into one I struggle with creating clothoids. With the Creator as a helper transformer I now know how to define them. But I don't know how to calculate the parameters 'endCoord', 'startCurvature' and 'endCurvature'. I guess it's just algebra, but I cannot find the correct formular.
I have following parameters given:
StartCoordinates x, y (m)
StartDirection (gon)
Length (m)
StartRadius (m)
EndRadius (m)
Any ideas?
  • Oct 14, 2022 7:29 AM UTC
Concerning the PathBuilder, you may have to make sure that the elements arrive to the transformer in the correct logical order, and that they are oriented in the order of the complete line. From the documentation of the PathBuilder:
If the end point of one input segment does not match the following segment's start point, geometry will be added to connect them in the following way.
That might perhaps explain what you're observing.
mariaka
  • Oct 14, 2022 8:29 AM UTC
Yes! Thanks @david_r​ ! I was already sure the lines are correctly sorted, but weren't.
mariaka
  • Oct 20, 2022 6:53 AM UTC
In case someone needs to know more about clothoids: http://ww3.cad.de/foren/ubb/uploads/Clayton/Klothoide-Formeln.pdf [german] helped me a lot!
