How could I execute a SQL "select distinct" command on an ESRI FGDB Table?
  • Mar 25, 2022 7:17 AM UTC
  • 86 views
I have tried using the unique value transformer but it only accepts a single column. The SQL Executor doesn´t read FDGB. So how could I do an SQL distinct on two columns?
  • Mar 25, 2022 7:45 AM UTC
You can always use the DuplicateRemover, it'll have the same effect except that FME will have to read the entire table first.
