How can split polygon (rivers/roads) into branch?
  • April 25, 2022
  • 12 replies
  • 387 views
How can split polygon into branch like this image?
Each branch showed by a number.
imageAnd the split positions are yellow lines like this
imageEveryone has any ideas to solve this my issue, please show with me! Thank you so much!
Best answer by geomancer
Good idea! But the challenge is probably in creating the lines to use in the PolygonCutter.
I've experimented a bit with some simple data to set up a basic workflow. There's still work to be done though!
Split_Roads_Polygon
connecter
Forum|alt.badge.img+10
  • April 26, 2022
Hi @pqtkha​ ,
have you try the PolygonCutter transformer? My example:
imageResult:
geomancer
Forum|alt.badge.img+60
  • April 26, 2022
Split_Roads_Polygon
  • April 27, 2022
Hi @pqtkha​ ,
imageResult:
Thank for your recommend! I tried the PolygonCutter Transformer but before that I have to extract the line which use to split the polygon. I need all step are automate processing from the input data!
virtualcitymatt
Forum|alt.badge.img+47
Another option is to use the the VertexAngleCalculator. This will create points where a vertex between two lines is greater than a chosen amount. You can then use the NeighborFinder in Candidates only mode to find the closet point (within a given distance).
imageThe result will not be perfect because of having to pick an angle but could probably be improved on.
Here's an example: Input
imageOutput
  • April 27, 2022
Split_Roads_Polygon
Wow, That great! Your ideas to solve this issue is amazing. I tried your workflow with your demo data. It's really work. I also tried with the real data with bigger scale and I saw a new issue that is the time to process at step NeighborFinder so long. I think because the number of neighbors to find assigned to number vertices is so small for each time to find. I attach my small demo data in below, you can test with your workflow. In fact, my data will bigger than 4 - 5 time with this demo data.
imageI greatly appreciate your helping!
  • April 27, 2022
imageOutput
Thanks for your suggestion on this issue. In your workflow from VertexCreator Tranformer to PolygonCutter that output of VertexCreator is points, but assigned to lines of PolygonCutter. Can you help me to clear more your idea! thank you so much!
I attach my demo data in below, you can use in workflow!
virtualcitymatt
Yeah I tested the input and it seems the VertexAngleCalculator doesn't work so well with polygons with holes in them. Plus I also see that the input has some intersections where the angles are pretty shallow.
Here the VertexCreator is adding in an additional point to a point making a line.
geomancer
  • April 28, 2022
I had not thought of the VertexAngleCalculator to identify possible locations of cutting lines. Good idea!
Other possibilities to get the angles at the vertices are the TopologyBuilder and the Intersector transformers.
  • April 29, 2022
I'm trying improve the workflow base on your ideas! If you have any new idea to solve this issue, please share with me! I really appreciate your help! Thank you so much!
geomancer
  • May 3, 2022
I've been looking at a couple of ideas for improvement as well. They all look great with simple data, but so far they don't work with real data.
One thing I found out was that the PolygonCutter is way too slow. The best solution I found for this was to use an Intersector and an AreaBuilder, and next remove the original holes.
Split_Roads_Polygon_Drop_Holes
jennychu
  • May 4, 2024
Good idea! But the challenge is probably creating the lines to use in the PolygonCutter.
I've experimented with some simple data to set up a basic workflow. There's still work to be done though!
Split_Roads_Polygon
hey @geomancer, I think your answer is interesting and exactly what I need! However, I met some problems during the transformer setting. Could you share your workflow/workspace with me? Thank you very much!
best regards,
Jenny
geomancer
  • February 19, 2025
Found it, see the attachment.
