How can I write point with text in gdb ?
  • Dec 4, 2022 5:55 PM UTC
  • 75 views
spiderman
Forum|alt.badge.img+7
I have created by text adder for polygon .
point with text name of polygon but I have noticed after writing them in gdb Esri api or in Esri shape file .
when I try to read the output again , I read only points ,i see it but I do not see any text with point ,why ?
i would like to have point with text as I have written ,Does it possible ?
Thanks in advance
FME 2021
chriswilson
Forum|alt.badge.img+29
  • Dec 5, 2022 1:08 AM UTC
You can use a LabelPointReplacer as in this tutorial:
https://community.safe.com/s/article/map-and-map-feature-annotation
spiderman
  • Dec 5, 2022 4:41 AM UTC
Hello ,
thanks for reply .I have used center point extractor as me zoomed in article then label point replacer .i can show the point with label name as I wish .
but I connect the output with geodatabase Esri api writer , I have found I have to used which geometry type ,I have chosen point .but later when I view written data ,I see only the points without any labels . Do u have sample workspace ,I am not sure what I missed here
