How can I execute an oracle stored procedure ?
  • February 3, 2022
  • 1130 views
I have created a stored procedure in oracle to refresh oracle materialized views, I turned to stored procedure because I was originally trying to do it in run sql after execution but it kept failing with invalid sql . No I have teh sored procedure and I have placed it in sqlExecutor to test and its still returning errors..
this is the oracle create procedure statement (names changed )
create or replace PROCEDURE "MYProcedure" AS
BEGIN
 DBMS_MVIEW.REFRESH('A,B,C,D', method => 'F', atomic_refresh => FALSE );
END;
and this is how I try to execute it in sqlCreator
FME_SQL_DELIMITER /
begin
exec NBPNBICASPER_VIEW
end ;
This fails and the only way I get no error (but nothing runs ) is put : in front of the procedure name )
FME_SQL_DELIMITER /
begin
exec :NBPNBICASPER_VIEW
end ;
What am I doing wrong .. Have I gone about this incorrectly? any help direction etc. is hugely appreciated.
Paul
  • February 4, 2022
Try using this syntax:
begin
    NBPNBICASPER_VIEW();
end;
See also https://community.safe.com/s/article/running-a-oracle-stored-procedure
If that still doesn't work, please post the error messages.
  • February 4, 2022
​thanks David_r , perfect answer …..    and I had tried this earlier and it was throwing errors so I decided it didn't work - but your answer made me persist - and it turns out that the issue was actually with the stored procedure in Oracle ..    fixed the procedure now and appears to work (on a test) FME SqlCreator is not throwing errors.
Thanks a mil for taking the time out to respond 👍
