How can I configure FME server to check out a license from the ArcGIS Pro pool instead of the ArcGIS Desktop pool?
  • Dec 14, 2021 4:10 PM UTC
  • 218 views
markvv
On our machine running FME Server, we have both ArcGIS desktop 10.6.1 and ArcGIS Pro 2.7 installed.
When we run workspaces that require an ESRI license, FME Server can get a license, but pulls a license from the ArcGIS desktop 10.6.1 license pool (As shown below). The same thing happens when the same workspace is run in FME Desktop.
2021-12-14 01:10:07 | The ArcObjects license 'Advanced' is being selected from the Windows registry
2021-12-14 01:10:18 | FME has checked out an Esri license. The product checked out is 'Advanced'
2021-12-14 01:10:18 | Installed ArcGIS version is '10.6.1'
How can I configure FME server to check out a license from the ArcGIS Pro pool? Preferably the advanced concurrent use license.
We followed the step by step instructions for using ArcGIS Pro with FME server in this article without succes: Using ArcGIS Pro with FME Server (safe.com)
Best answer by rahulsharma
hi @markvv​
The easiest way to do this would be to set the PythonCompatability in the workspace to be "Esri ArcGIS Pro 3.6+" instead of the default FME Python.
NOTE: This will need to be done to all the workspaces which can be a bit difficult.
rahulsharma
Forum|alt.badge.img+12
  • Dec 14, 2021 5:42 PM UTC
hi @markvv​
hkingsbury
Forum|alt.badge.img+73
  • Dec 14, 2021 7:09 PM UTC
hi @markvv​
Internally, we have a setup script that gets rolled out as part of our Python Install. This sets a range of registry keys, one of which is changing the default python version to ArcGIS Desktop. This doesn't effect exisitng workbenches, but will set all new workbenches to use the specified python version.
I don't know off the top of my head what the correct string is for ArcGIS Pro....
[HKEY_CURRENT_USER\SOFTWARE\Safe Software Inc.\Feature Manipulation Engine\Python]
"PythonPreferredVersion"="ArcGISDesktop"
