How can I buffer outside a polygon only?
  • Mar 31, 2023 3:09 AM UTC
  • 6 replies
  • 391 views
hoskinmi
Forum|alt.badge.img+5
I have have a set of polygons (actually they are buffers of a point) and I want to buffer these again to leave a ring - just keeping the buffer outside the original polygon. I can do this easily in arc/arcpy by using the buffer type "OUTSIDE_ONLY". How can I get the same effect using FME? I have created the buffers but when I use the clipper to clip one out of the other it clips all the overlapping buffers (which is what I expected) but I can't seem to figure out how to get the result I would like. I feel like I need to split each of the the buffer datasets so that it does the clip on each pair of polygons separately but - I'm new-ish to FME so.... Can't seem to find anything to help online either.
This is what I have - the attribute managers are just to fill in an attribute so I can put the two buffers back together in one layer and be able to identify which polygon is which type.
imageThis is what I would like to end up with:
imageNot this:
Best answer by tomfriedl
Have you activate "Group Procesing" in the clipper params?
tomfriedl
Forum|alt.badge.img+14
  • Mar 31, 2023 5:51 AM UTC
dustin
Forum|alt.badge.img+36
  • Mar 31, 2023 10:19 AM UTC
Agreed on the Group By Processing in the Clipper being the key. If you don't have a unique attribute on the features, you can create it in your AttributeManager.
@hoskinmi​ or try AreaOnAreaOverlayer instead of Clipper
hoskinmi
  • Apr 3, 2023 10:09 PM UTC
Thanks so much - that did it - and super easy too! How did I not see this? :)
hoskinmi
Thanks for helping - this was the solution and I do have a unique id already so it was very easy.
hoskinmi
  • Apr 3, 2023 10:11 PM UTC
I didn't try this as the Group Processing on the clipper did it but thanks so much for helping. I'll get my head around the AreaOnAreaOverlayer at some point I'm sure.
