how can I arrange attribute in assending order like: 5,6,3 = 3,5,6
  • Jun 23, 2023 7:45 AM UTC
  • 80 views
also i have check FME python caller but its not work.output is not generating.
import fme
import fmeobjects
class FeatureProcessor(object):
  def __init__(self):
    """Base constructor for class members."""
    pass
  def input(self, feature):
    cell_value = feature.getAttribute('Address Component Type')
    cell_value2=sorted(cell_value)
    feature.setAttribute('sorted',cell_value2)
    self.pyoutput(feature)
  def close(self):
    """This method is called once all the FME Features have been processed
    from input().
    pass
Best answer by ctredinnick
AttributeSplitter -> ListSorter -> ListConcatenator. It'll probably have similar performance to python because you keep the same number of features throughout.
ctredinnick
Forum|alt.badge.img+22
  • Jun 23, 2023 8:16 AM UTC
nielsgerrits
Forum|alt.badge.img+67
This is because the result is a list, not an attribute. You can see this if you enable the Feature Information window and select the feature:
2023-06-23_10h15_34
Thank you! It's Work
2023-06-23_10h15_34
Thank you!
